ehuppert
- 142
- 43
- Upstate NY
M1008:
So, have upgraded (this year) from a 7.5' to 8' Fisher speedcast plow.
Headers and exhaust installed when truck redone were fine until I started plowing last year. These were used Hookers from my Camaro... Header to front shaft interference is pretty common on the square bodies. Replacing headers would mean redoing front pipes, which are new! Only sags .5 inch when plow lifted currently, but suspension bounce will cause issues. (Shocks are good/new)
So, thinking of installing new 4 leaf packs for a little additional clearance. I could install zero rates, but if I went that route I'm halfway to spring install (labor wise)! U bolts were replaced when truck redone, have never been on road and will come apart...
How much harsher is ride with the heavier springs?
Anyone installed 4 leaves and documented additional height?
thanks, Eric
thanks, Eric
