ckid
- 89
- 18
- Waynesville, NC
OK, I've searched the forums and haven't found this answer. If I've missed it, point me in the right direction. If not, here goes...
I've never crawled under a Deuce except for mine, so I'm not sure what the proper vent line from the air pack looks like or where it runs. I'm assuming the line in these pics is the vent line. This is on a short style air pack. The line originated from the bottom outside of the air pack, runs up and across the frame, and then ends pretty much behind the battery box (see yellow arrows in pics).
About halfway across the cross member frame rail, there's some kind of box I'm not familiar with inserted in the line. The end of the line terminates is a fitting I've never seen. Granted, my knowledge of air lines is next to zero.
I read a lot on here about folks with air packs venting to the firewall behind the air box in the engine bay. This one doesn't. To me, it doesn't even look like this line is open for venting, but I don't know.
Don't know if it's supposed to look like this, or someone did a hack job separating the brake venting from the fuel venting at some time in the past. My master cylinder never had a vent line. Just a cap when I bought it. Since then, I've put a remote reservoir on it. But this air pack line, I'm not sure what's up. Hoping someone can offer some insight.
