Karl_William
- 10
- 3
- Missouri Ozarks
Hello all,
I could use some ID help. I recently acquired a truck that believe is a CCKW that was converted to a tow truck. The few things I do know/have read about aren't helping much. It is 6x6. The cowl says Chevrolet not GMC. The engine is a 235 not a 270(probably swapped in the late 50's early 60's maybe.)
I've looked in the usual locations on the frame rails(both sides) for any number stamps. I can't seem to find any where they should be. There is a single "S" stamped on the passenger frame rail side just in front of the friction shock. There are three plates riveted inside the cab, above the windshield. I believe they were painted at one time. All rust now. One plate has a six digit (no letters) number stamped into it. The number is 445347. I'm pretty sure it was a military vehicle at one time as it still has the blackout lights on front fenders. Was there any non military commercial usage of these trucks? Also it has winch on the front, but it looks half home made mounts. I think it says Tulsa winch on it. There's one of the same manufacturer on the back just behind the cab from the tow rig. I'm wondering if the frame may be stamped somewhere behind the cab? There is a LOT of home made plating of the frame to support the tow rig.
