- 2,828
- 3,925
- Montgomery, Texas
How do the bows fit in the bow storage mount?
@Guyfang, you Sir are a TM ninja! Nicely done!Ha! Got it!!
Where you mounted the P-Tool rack, is supposed to be (Figure 537) the Adjustable Safety Strap and Bow Stowage Strap position. Go to TM 9-2320-272-24P-2, Figure 537, (PDF reader page # 472) to look at what it is, AND should be/look like. There is a few parts missing.
Not sure, but I'll find out tomorrow!How do the bows fit in the bow storage mount?
Do I need straps on both sides?The uprights and elbows go in the front headboard. The top bows go under the bed as GUYFANG stated, and KENDELRIO acknowledged. The top bows are secured using the straps. If you have six top bows in that storage location with the straps tightened, they are not going anywhere.
I no longer own one of those trucks, but I believe there were straps on both sides. I do know that I have had trucks with straps on one side only so maybe that is the way they came? I don't fully remember, but I know I've also had trucks with straps on both sides. With that said, I never used them. I either had bows on the truck that stayed on with a cargo cover, had no bows on the truck (and no cargo cover), or took the bows off in a complete assembly and stored them that way.Do I need straps on both sides?
That is the mounting location I've had previously! Again, only a few M939 series cargos I've owned had the pioneer rack.Sorry for the delay.
See the pics.
Another use for the under bed storage area for the bows is for the medium tow bar using tmg bracket
Yes, should be a pair of straps on both sides attached to that 'z' bent threaded rod.Do I need straps on both sides?
OK, just checked the drivers side, no straps. Hmmm I wonder if our very own @Valence would know where/how to get some. They are NSN 5340009302717
According to TM9-2320-272-24P-2, each one of the straps has a different NSN (and Part Number):OK, just checked the drivers side, no straps. Hmmm I wonder if our very own @Valence would know where/how to get some. They are NSN 5340009302717
