dschoolxlt
- 8
- 3
- Youngstown, Ohio
Hello All,
I have the 803. I’ve replaced the fuel return lines a few times with the standard issue cloth covered line. For some reason, I keep getting leaks on injector #3. The line either works it’s way off the injector, or separates at the tee. I tried a low tech solution of using a zip tie for a clamp, that ultimately keeps the line in-place, but it has a drip
I noticed it after running a load test. It appears the constant fuel leak over time dropped and ran toward the front of the engine toward the water pump plate. I ended up having a coolant leak between the plate and block. I replaced the pump & all gaskets, ended up using black oil resistant RTV with the gaskets in the hope that it will semi prevent it in the future. I have to assume the diesel fuel is what lead to the other gasket failing over time.
anyone else seen this?
![32052FA4-8C78-4E62-979B-295F6FD0BA09.jpeg 32052FA4-8C78-4E62-979B-295F6FD0BA09.jpeg](https://www.steelsoldiers.com/data/attachments/608/608276-75ea2be90711f2a0d1f8a2ba498d3ffb.jpg)
