Hello, I recently purchased a 1997 M1102 from a private party. It came with the cover, hoops, and mounts, but the cover was trashed, so I replaced it with a new green cover from https://www.easternsurplus.net/. I also purchased new (old stock) shocks and reflectors from https://www.easternsurplus.net/. Additionally I purchased three unused 2018 BFGoodrich Baja tires from https://csmarmytires.com/ and three wheels from http://www.trailworthyfab.com. I'm very happy with the products and service from all three companies.
I mounted all three tires, installed the shocks, and undercoated using "Fluid Film" which I've used on my 3/4 ton Pickup. The trailer had some surface rust, but it's still solid. I also purchased 10mm rivnuts and replaced many of these for the cover mount attachment points. Also found a 7 pin connector on Ebay and replaced the NATO connector. All of these maintenance procedures went well. The previous owner had already changed it to a 12 volt LED system.
Question: Can anybody identify a source for the correct rivets used on this trailer? I need to replace the reflector covers with the parts from Eastern. Thanks!
Random photos below:
![m1102 new wheel & tire.jpg m1102 new wheel & tire.jpg](https://www.steelsoldiers.com/data/attachments/610/610304-3ac2ceba021ac5d4e9a3e611a9b6156d.jpg)
