- 122
- 81
- 28
- Port Angeles, WA
That looks like box 2002386......in which case they are referred to as 'non-metallic corner screws'....Supplier for the bare box was Vynckier...they got bought out by Hoffman...I bought what appears to be a nice one, still have to test it properly. It is missing one of the corner fasteners. Anyone happen to know where to get one or what to even call it?
View attachment 855175View attachment 855174
Try this:
Has their phone number too for enquiries...
Let me know if you need any help to get it up and running...glad it is working for you...I knew when I posted, it was a long shot, but I am super Impressed! You sir, have exceeded my every expectation! I gave them a call today, they are suppose to check on those Metal Free Screws (what they call them) and get back to me. Thank you very much!
I hooked it up today to the powersystems Drash with 60A cable. Lights on panel came up. Tested outlets. One side working, one side not. The side with the 2 GFCIs is not running. But both are super caked up, and the buttons for test and reset can't be pushed in. Wiring on inside seems ok... I ordered a couple Liviton WeatherRated commercial GFCIs, I'll see if I can swap them out and get it going.Let me know if you need any help to get it up and running...glad it is working for you...
Those are wired so that the 60amp connectors can be daisy chained to other boxes and cables and the three individual GFCIs are each wired to a phase, Phase A, B and C... Odds are it is the GFCIs as you have surmised....If you can confirm it is 2002386 as the part number on the label of the box I can send you the schematic and the wiring diagram.I hooked it up today to the powersystems Drash with 60A cable. Lights on panel came up. Tested outlets. One side working, one side not. The side with the 2 GFCIs is not running. But both are super caked up, and the buttons for test and reset can't be pushed in. Wiring on inside seems ok... I ordered a couple Liviton WeatherRated commercial GFCIs, I'll see if I can swap them out and get it going.
That would be great! I can shoot you my email if that makes it easier. Part is indeed 2002386.Those are wired so that the 60amp connectors can be daisy chained to other boxes and cables and the three individual GFCIs are each wired to a phase, Phase A, B and C... Odds are it is the GFCIs as you have surmised....If you can confirm it is 2002386 as the part number on the label of the box I can send you the schematic and the wiring diagram.
