Mep806b challenges
319cssb
221
Easley SC
So the mep806b stopped functioning just as I took possession of it. It turns over but does not start. Starts with ether (for a second) and starts with the IP jumped with 24v . Bought a new speed sensor as the old one only showed some 500mv ~. The new sensor did the same and a sensor I dug out of a mep802 did the same reading. The mep802 has a shorter sensor which is helpful. Installation is still a pain in the dick , but far more manageable than the 806b sensor.
the first sensor I removed had some rust flakes stuck to it. Could it be that the flywheel is so rusty that it messes with the reading of the new sensor?
What to do next?
319cssb
221
Easley SC
Can someone verify if there is a magnet on the mep806b? Or is there a gap that throws out the signal for the sensor?
319cssb
221
Easley SC
I should have phrased that better. I meant is there a magnet on the flywheel as well ? Or just the teeth on the flywheel that make the sensor pick up the AC current?
@Guyfang already answered it, but when I read it again. My question didn’t make much sense to me.
319cssb
221
Easley SC
I got a new sensor and got it adjusted to 1.5vac but no I noticed that the speed control module has no dc power LED on
jmenende
384
Puerto Rico
Disregard the manual. Adjust from 2.3vac to 3vac. 3vac is best. Go slowly using the dead crank cause if you get it too close it will shave of the magnet and ruin the mag pickup. Once you get that done the speed sensor on the govr will light up.
jmenende
384
Puerto Rico
Do not go over 3vac. You might slip up and ground off the tip. Leave it at 3vac and troubleshoot the next issue. Check the connections to the governor. Contact cleaner is your friend. Make sure you pull the fuse before you spray everything down. Do you have access to the canon plugs behind the control module?
jmenende
384
Puerto Rico
Did you remove the governor before? By looking at the pic, the top left nut is missing. Maybe someone fooled with it before or swapped the governor. Is this unit new to you, have you ever seen it run right?
319cssb
221
Easley SC
Have you worked on or own a 806b?
