I noticed the passengers side KC light was out last week. Today I decided to get the part information for the non-working light, assuming the bulb was just bad. In the process I discovered the KC switch inside wasn’t working nor lighting up green. Now neither of the KC lites are working at all.
I’m beginning to think that it’s the Brown Ground Wire, the end opposite of the end that goes into the switch. As you can see it’s just hanging there not connected. That U shaped end. I’m thinking it just came loose. I also noticed there’s a red wire with a black stripe connected to the brown wire. My spotlight hasn’t been working for a while either. Maybe the Red Wire (with Black Stripe) goes to that? Maybe not.
I have 2 Questions:
1. Where should I attach the end of the brown wire?
2. Should I be worried about the red wire, with a black stripe, being attached? As not to fry anything, etc.
Thank You for any help guys, I appreciate it!
