Fuel Pod Moved
Guyfang
27,314
Burgkunstadt, Germany
I seem to remember there being a possibility of using the same 5 gal gas can adapter, with the brass screw in pipes, in a ´n opening on top of the tank. Do you have the TM's for the TPU stuff?
SCSG-G4
PSVB 3003
5,403
3,508
Lexington, South Carolina
Yes, thanks for asking, and I have extra adapters (hardware). Problem with the adapter and vacuum is that all the tanks will try to reach the same level and they are NOT. I would much rather run the electric pump from the 600 to the 55 and keep it full when I do my daily checks and services on the generator, and let the aux fuel pump keep the 'day tank' at least 3/4 full. With the weather conditions they are calling for this weekend - tonight thru Monday noon, the machines could get a workout even though the 600 is still empty. I think I may be prepared for generation with three MEP-003A's, a diesel 5KW commercial unit, a gasoline 5KW commercial unit, an old Craftsman 3000W gasoline generator and a 2000 watt 'quiet' generator. Time will tell. And two 803's across town at the club compound.
