- 324
- 90
- 28
Starter truck this afternoon and alarm would not stop,break lever is down ,what do I need to look at to stop Alarm.
So If I hit it with a hammer alarm wil go off along with indicator light and I will have breaks.Under the dash. Right above the drivers fresh air vent. Smack it with a hammer or unplug it.
Break light and alarm is what I'm concerned with, that is my alarm.I drove it a little alarm. My street and it had breaks but I wasn't about to take any furtherFailsafe alarm notorious for “failing”, if your low air pressure and parking brake warning lights are still functioning correctly put a piece of tape over the speaker until you decide if you want to spend the money to replace.
If you have air pressure you have brakes.Break light and alarm is what I'm concerned with, that is my alarm.I drove it a little alarm. My street and it had breaks but I wasn't about to take any further
What does the air pressure gauge say? If it is within the normal range, the brakes are safe. The alarm is to call your attention to the gauge in case you're not looking, when a failure occurs. Sounds like a simple buzzer failure.Break light and alarm is what I'm concerned with, that is my alarm.I drove it a little alarm. My street and it had breaks but I wasn't about to take any further
Thank you for your reply, the air pressure was up there,as of now l am down with a cold and perfer to stay in side.What does the air pressure gauge say? If it is within the normal range, the brakes are safe. The alarm is to call your attention to the gauge in case you're not looking, when a failure occurs. Sounds like a simple buzzer failure.
Both the brake light and alarm would not stop,I was going to allow my son to take it to work with all this snow we were hit with but I wasn't going to take it with the above mentioned.
When l do go out in the next few days l will answer your air pressure question.
Thanks wayne
