No not yet, trucks had a 12v conversion previous to me. Hopefully get to it this weekendHave you taken the gauge cluster apart, cleaned every surfaces and the bulbs themselves? Along with making sure the bulbs are the correct bulbs for that application? What is your voltage off the front battery with the engine running?
That has nothing to do with the dash /luster lights. They are and always were 12 volt on a CUCV. Only thing 24 volt was the starter. Good Luck.No not yet, trucks had a 12v conversion previous to me. Hopefully get to it this weekend
I just replaced mine but didn't use leds...I am a big led guy and think the gauge back ground lights can be led....the ones I use can be dimmed and work great...I am not sure if they can be used for the alternator warning lights as the power may not pass through like a conventional light bulb to get the alternators to work...have you tried them in those before? I have a set of white leds I am planning on putting in there but don't want to fry a regulator in an alternator I just rebuilt! I may just keep those regular bulbs.LED for the win...
