ghog50cal
- 9
- 8
- Marietta ok
i don’t have 24v at k1-86
The trans panel is up with no codes and neutral neutrali don’t have 24v at k1-86
OK, good, we know you have main trans power thru CB79 otherwise the trans wouldn’t even light up, but the trans and VIM are fed from 3 places. Do you have 24V to/thru CB21? That is the power that feeds thru the neutral relay in the VIM. You also need to make sure that there is 12V getting to-thru CB35. That 12V is the VIM power. If you do, you will have to remove the passenger kickpanel to get under the passenger dash.The trans panel is up with no codes and neutral neutral
I don’t think px33-f1 has any powerI’m not sure which ones px33-f1
OK well I think PX33 is larger than the other connector. If you look inside the connector the pins should have small molded labels. F1 is the 24V in for the start circuit so if you are sure power is getting thru CB21, you can pull it out and either jumper across CB21 or insert a standard automotive blade fuse in it’s place To be sure.I don’t think px33-f1 has any power
when I press the start button I’m getting a click in k1 now but the starter is not activatingI don’t know what I did but I now have power at k1-86 still no start from the switch
So could be a bad aux relay on the frame or a disconnect down there. I would look for voltage from K1 making it down there.yes that’s with the relay In place
87 too ground is OL
