TOM R
- 91
- 28
- sewell n.j.
I will definitely be finding a way to seal those b beam holes in the trans tunnel ,that alone should cut down on noise and heat
You mean the big holes on side of tunnel, under the brace? Those are not open to under the body.I will definitely be finding a way to seal those b beam holes in the trans tunnel ,that alone should cut down on noise and heat
