Gas Conversion
TurboLSHumvee
Southern Californa
I thought you guys might appreciate some of the work done on my humvee.
Here is the video the guys made who did the LS/4l80 swap:
Since then I have changed a few things around. Once I get this tune figured out I should be conservatively around 600 hp.
Below is some of the early fitting and fabrication:
I ended up having to replace the transmission/oil cooler as there was not much room under the hood with the intercooler stacked on top.
williamh
701
SanDiego Ca.
Why would you convert to gas ?? I could see going for the duramax conversion but gas ? Is it at least an ls1? . I just couldn’t pull the trigger on an gas motor when diesel with a turbo has way more power
  • Like
Reactions: 98G
TurboLSHumvee
Southern Californa
Because I wanted it to be that way. It's a 6.0 LSx. It gets better power and fuel economy that the original setup. Gas is more plentiful than diesel. It's easily a 300k mile motor. Any shop can work on it. Parts are cheap. Sounds like boosted muscle car instead of a tractor.
Mogman
10,491
Papalote, TX
While I do not have any problem with anyone putting any engine they want in their HMMWV, I do take exception to my 435HP Duramax being compared to a tractor, it has a awesome bark that would rival any gasser once the tires quit squalling, well maybe not as nice as a V12 Maserati,,,
mgFray
992
Southern Minnesota
For a short period of time I worked (as an outside contractor) for Magneti-Marelli in Turin Italy. One day I show up to the building, and I hear what sounds like a dump truck dieseling it's way toward me, passed me and continued around the building. I turn around and it was a V12 Maserati. By the time I walked to the door of the building I was going to, I heard a smooth running engine behind me.. same vehicle, but this time tuned properly. They were apparently working on the engine computer, timing, etc.
I'd never heard a gas engine sound so much like a diesel before, lol. So ya, even a nice V12 Maserati can sound worse then a truck diesel.
jrtoffroad
180
Colorado Springs, CO USA
Pretty awesome! Is it up and running? (Haven't seen the video) What size turbo did you go with?
I'm a big fan of the LS swap HUMVEE and have been debating going this way. But both are awesome, just comes down to personal preference I guess.
For me, the main pros of a diesel are fuel economy and towing ability. While the pros of gas are cost, size, weight, throttle response, and sound (6.5 diesel - the most efficient conversion of diesel fuel to ear splitting rattling engine noises without the side effect of hp).
mgFray
992
Southern Minnesota
One more advantage/disadvantage. Gas, no glow plug or glow plug controller. Diesel no "old carb" or "complicated" ECU that needs to be tuned. Add to that gasoline generally doesn't gel in the winter. ;)
98G
Former SSG
4,866
Diesel - far less flammable and less dangerous to have around. Much longer shelf life (although far less than it used to be).
To each their own.
Agelai
Get some
64
13
Florida
I too am thinking of swapping to a gas setup. I did all the research on the Duramax and Allison swap, but for me the price is just insane. For half the price you could do a LS or Hemi swap, and get 500-600 hp easily.
so I get it.
I think the major advantage is cost, anyone can work on it, aftermarket parts, etc.
Sick job dude.
Vapor Trail
282
Kentucky
I appreciate your video, thanks for posting! Not sure why some people are so negative about another persons swap. Honestly I have a brand new Duramax and its not that impressive. When I finish my swap I'll run it next to my L86 V and we'll see what happens and I'll post a video here.
Rpaint82
kansas city mo
Im looking into an LS swap also as my 6.5T needs rebuild or replaced in my M1167. I have swapped a few motors in my day and just did a blown 5.3 to 6.0 in a silverado. Any tips or advice in making my process easier? kits? motor mounts? Stand alone systems? My shop is set up with just above basic tools and my welder is good for exhaust or maybe some sheet metal. I would love to keep my A/c working so Im sure this will be a long road!
