Buderwuder
What is the correct way to install the oil seal in the drum on the worm gear/bull gear end. I have looked in the manuals and cannot find the right way. I already installed one with the spring side of the seal facing out or towards the housing when installed. I am beginning to believe this is incorrect, because the drum does not go done the shaft far enough to allow for the keys to go in the shaft on the clutch end. Also does anyone have the torque specs for all the bolts on the winch?
