- 249
- 70
- 28
- San Antonio, TX
I am attempting to return my m1009 to stock wiring (for the most part), with regards to the GP and starting wiring. I am having some issues.
What I had and what I've done so far:
PO put a 6.5 IP in. It recently died. Got a rebuilt 6.2 IP from Badger Diesel. The 6.5 IP was drawing power from the 24v bus through a switch mounted in the dash. (The engine would stay running with the key off until this switch was flipped to off)
There was no glow plug card at all, and most of the wiring leading to the GP card was cut. I have reconnected all the like wires together. New GP card from hillbilly wizard is installed.
PO had the glow plugs activated through a push button wired as follows:
12v bus --> GP relay --> Momentary push button --> (grounded on starter relay)
The light blue and pink wires from the GP card were not connected to anything and just hanging out under the GP relay.
Looks like PO replaced a fusible link from the 12v bus with a fuse holder. It had a melted 30A fuse in it. Replaced that.
Passenger Alt was having issues, I rebuilt it according to the instructions in the stickies.
Now the issue:
I had power with the key in the run and start positions before I pulled the GP push button and 6.5 IP wiring.
Now I don't have power with the key in run or start.
Headlights, turn signals, brakes, horn all work.
Replaced the ignition switch (the lower one the push rod on the steering column connects to). Read this can go bad. Did not solve anything.
Jumping the starter relay with a beefy wire engages the starter.
I have not finished tracing all the wires yet, but I'm hoping I've missed something that's obvious to someone else.
I am a getting a bit lost in all the wiring diagrams. Can anyone show me where the 12v is supposed to come from when you turn the key to Run?
I also have some mystery plugs in the engine bay. They may or may not have anything to do with the issue.
3 plugs with multiple wires on each IVO the fuel filter. They all come out of the same harness that runs behind the engine. It's been changed to spin-on. One is the water in fuel light, the other 2 seem to be too short to reach the old filter housing, some help would be appreciated in identifying them.
A 4th mystery plug is underneath the master cylinder. A single wire plug with a blue/red wire. No idea what this could be.
I am fairly certain I have the GP relay wired up correctly (stock). Can anyone verify?
I'm ready for the @ss chewing
Sent from my LM-V600 using Tapatalk
Now the issue:
