Do we have a part # or equivalent to the 12/24 battery rectifier?
Reworked LMTV
1,566
1,214
TN
Do we have a part # or equivalent to the 12/24 battery rectifier? I believe mine is starting to fail. Thanks!
Suprman
707
Stratford/Connecticut
The polarity box under the spare tire? You can bypass it. What makes you think its going bad? The main grounds go bad I always add a new big ground from the batts negative to a sanded spot on the main frame rail.
Reworked LMTV
1,566
1,214
TN
Yes, the polarity box. I am getting current leakage, evident with lights staying on after turned off, but dim. Good idea about the grounding.
