Found this under my truck.
blutow
501
Austin, TX
I don't think so either. I've ran it a few times up and down the street, no leaks. Trans full, oil fuel and power steering full.
I went over every inch and didn't find anything missing.
I did get to finish my 4 door conversion! So now I wait on sf97.
Looking good. Glad you got past you IP issues and on to some fun stuff. Looks like we are about at the same stage, I got my top on this week as well. I just did the rear jump seats instead of the buckets. When do you plan to tackle your tires? I've watched a few youtube videos and it looks like a pretty grueling process with the runflats. I'm planning to give them a try. I ended up getting some 24 bolt rims that I'm going to repaint before mounting up my tires, so I' hoping you will share you experience if you get to yours first.
Mattguy
1,333
Highland, Indiana
Yours looks awesome with the camo top! I got the Arctic because that's all I could find.
Tires should be here tomorrow, they were delayed in Wisconsin due to weather. Split rims are easy to deal with. Make sure you get new o rings. I'm not using the run flats so hopefully pretty easy to put on.
Mogman
10,332
Papalote, TX
Just because it is not rusty does not mean it is stainless, put a magnet to it!
If it was a MC fork top plug it would be chromed, I think if both the plugs are in the TC then it was an extra that was placed somewhere and forgotten about or lost and was replaced because the tech. could not find it.
