- 7,473
- 10,487
- Papalote, TX
Dang, spring break starts this weekend, no bikini's on the beach!!!!
.Dang, spring break starts this weekend, no bikini's on the beach!!!!
They revised the forecast for the beach, Sat 40-49, Sun 42-50,,.
Why Not!?
Too cold?
Say it ain't so!!
To answer this, there was no issue in low range, I was monitoring it on the laptop and it went into lockup in second gear and stayed there as long as I was feeding it fuel but I have noticed that in gears between 2nd and 4th the TC will go out of lock most of the time when the accelerator is at 0%, then as I add fuel it will within a few seconds will lock the converter again.Wow. The rpms do drop in last gear. I most definitely would consider this mod. Is there any concern with offroading and the converter lockup?
Not that I can think of, have you received the documentation from Zero Gravity, if not ask them for it.I'm starting to buy the individual items for a swap. I saw this dual brake switch. I know you only needed rpm and tach signal. Is there any added benefit with brake signal? I was thinking one side for 24v and other for 12v.
