Is this alternator defective?
Robtstee
12
Orlando, FL
First, I know how to test an alternator for function. I am concerned with connecting this alternator. Had a problem and burnt all the fusible links and smoke came out of Gen 2. Fixed all the links and installed a new alternator. Marked all wires when disconnected. It is wired per the diagram. Have tested for negative terminal isolated from case. Went to put on Bat 2 negative, got sparks. Disconnected and traced till I found the + term on Gen 2 to the 24v Buss was causing the sparks. With all wires disconnected except the neg terminal I've got 12v on the neg terminal, 12v on the exciter tab, 12v on the wire to the 24v buss and 12v on the little pin. Exciter wire 0v with key off, 24v on. New alternator, but the situation was the same with the old one. This may be all be normal but, I am unfamiliar with this setup and would like to know for sure before burning anything else up. Thanks in advance.
20,738
Gen 1 and Gen 2 are different (or should be different from a normal Chevy alternator). Both must have an Isolated Ground and that is pretty important. Picture attached
EDIT: Both Alternators are isolated ground and Both are the same. Thanks for the correction MarcusOReallyus
porkysplace
1,496
mid- michigan
From the cucv hepful threads
20,738
Thanks porkysplace !
That is a lot better than the little offering that I posted for Robtstee
Guruman
Not so new member
494
1,074
Cody, Wyoming
Gen 1 and Gen 2 are different (or should be different). Alternator 2 must have an Isolated Ground and that is pretty important. Picture attached
It might also be worth mentioning that I've seen alternators that have this bolt/connector, but were NOT really isolated ground. If you have continuity between that bolt and the metal alternator body, it's NOT isolated.
I've also had folks get twisted up with the nomenclature of "isolated ground" when indeed that connection on gen2 does not go to ground, but rather 12v positive.
Good luck.
Robtstee
12
Orlando, FL
Thanks for the fast help, I read the article, but I think my question is more about the alternator than the system. I verified the Negative terminal on Gen 2 is isolated from the case with a known good meter. Verified the negative terminal on Gen 2 is getting 12v from the diamond on the firewall. The only wire connected to Gen 2 presently is the negative terminal(12v). So my question is it normal to have 12v on the Gen 2 positive terminal(disconnected) and the Gen 2 exciter tab(disconnected) with only the negative terminal(12v) properly connected? If so, that would explain the sparks when I put the rear Battery ground on. Thanks again
Tow4
674
Orlando, FL
Both alternators should be isolated ground if they are original to the vehicle. If you are not sure if the alternator works, take it to be tested or follow the testing sticky at the top of the CUCV forum and just connect the alternator directly to the appropriate battery as described in the test.
Robtstee
12
Orlando, FL
To anyone who is in the same situation I was: I was asking if it was normal to get some sparks when hooking up the rear batt neg cable and normal to have 12v on gen 2 + terminal with that wire disconnected. Knew how to wire it up, knew how to test it for output, was afraid to connect it and burn the links up again. I took all wires off both alternators and checked and compared continuity and resistance between every connection. They all matched, figured there was no short in the new one, hooked them both up and all was good. Hope this helps someone.
