Accessory rewire
ldmack3
1,740
N. Central Idaho
Finally finished re-wiring the added accessories. I never liked the idea of running power wires thru a switch directly to the item. So I added a relay panel; behind the companion seat.
Control panel L to R: Bar Light, Running lights, back up light, back up horn, cameras (future) and crane.
Didn't wire the back-up to come on when selecting reverse as there are time when I might need them without selecting reverse.
Power is through resetable CBs.
Relay panel as well as control panel are installed with connectors so easily removed.
Relays are mounted behind companion protected from anything thrown under the seat. (Still working on this cover).
I did not go to the overhead as I did not like access for the wire run. There is a hole in the center windshield structure on the top but nothing on the bottom. Windshield could be folded and a new hole drilled on the bottom and larger hole drilled on the top. This would be prefect, except I have a fiberglass top that wraps over the windshield frame so would have to be pretty much removed. Then if I ever wanted to run with the top off and WS down I would have to disconnect everything. May do this when I add camera and radio, not sure yet.
SteelNinja
174
Hills of / TN
Thanks Brother, This give me some ideas... I'm also wanting to add 12v to my system- some say to add a 12v altanator and separate battery , which I hope to do asap.. I would think someone would have a bracket made and altanator as a kit - But I gues I can made something . I'd like to add a stereo and high watt amp - so the stereo can compete with the C Turbo LOL
INFChief
1,348
New York
Do these relays eliminate the need for a circuit breaker / fuse?
cbrTodd
507
Indianapolis, Indiana
No. Go ahead and invest in yourself and the happiness of your truck. Fuse or Circuit Breaker on everything that you add will be your best plan.
I would add to that, that when you are putting fuses or circuit breakers in the system, get them as close to where they get power from (+ battery terminal, 12v power converter, etc.) as possible. That way you have less unprotected wiring that could still cause a short without protection from the fuse.
20,720
For sure!
The closer to the power source that the fuse is, the less chance of letting the smoke out of the wires will be.
G744
4,104
Hidden Valley, Az
If it's not 24V, it doesn't belong in a tactical.
Get the right stuff, don't make it into some Lazy-Boy recliner on wheels.
Geez...
DG
