jplace1011
- 488
- 63
- Santa Ana, CA
I’ve noticed that when I start my CUCV M1009 up the lights are dim and flicker. The Voltmeter is in the Yellow. The Water in Fuel Light will flash and then the lights and Voltmeter are normal. The interesting thing is the aftermarket Oil Pressure Light seems good all the time. Video from today below:
The other day the Water in Fuel Light was at a constant flickering too. It doesn’t seem to be doing that any longer. I just want to mention it. Video below from yesterday:
I recently did a lot of work to the dashboard: replaced the circuit behind the instrument bezel, installed LED bulbs, painted the gauge needles, etc.
When the Water in Fuel Light was constantly flickering I double checked the Big Plug at the rear of the instrument panel. I disconnected it and plugged it back in. That seemed to help and stopped the constant flickering. Still, now it’s doing this Flash and suddenly power is normal thing.
If it matters, I also replaced the both alternators, the temperature sensor, the glow plug card and relay late last year.
I’m not sure what exactly is going on. Is it the truck just needing a short time to get back up to the proper volts once the alternators kick in? Could it be the Fuel Sensor in the fuel filter needing replaced? I checked the wires for that sensor and they seem in good shape.
You guys have been so helpful. I appreciate any input with this! Thank you thank you!
-JP
-JP
