M1078a1 - Starter Flange Play
gslader
291
California
I was doing a quick PM once over on my truck today and noticed a bit play - about 1/16" - between the starter and the starter flange (video below) - which means I'll need to pull the entire starter off to tighten the flange. I'm assuming there is no such thing as a "good amount" of play between my starter and the flange - but before I pull it off I thought I'd check. . . .
20,760
Like @GeneralDisorder said, pull it and fix it. LocTite is your friend. OR check it after you fix it - then after every third or so crankings - check it again.
Keeping your starter working and not having to buy a new one is a lot like a wife. If you call a starter a girl or give it a girly name - the Cheaper To Keep Her mantra comes to mind. :)
Hey - we gotta have fun here - and I hope you got a chuckle out of my post.
Plasa
334
Italy
I will bring this topic to the first page. On my starter 2 of 5 bolts where broken and only 3 of them hold the entire starter in place. All of them where loose.photo_2025-01-20_17-17-36.jpg
Christian
gslader
291
California
Glad you caught it early. This seems to be an issue with some of these trucks. That was a real pain re-installing the starter (for me anyway!).
Plasa
334
Italy
Definitly.
What wrench did you use to close the 3 bolts that connects the flange to the flywheel housing?
I changed them to normal hex screws because the original ones are difficult to tight up...
Christian
gslader
291
California
Definitly.
Christian
It’s been a while, but as I recollect the bottom, two bolts weren’t too tough to get tightened. However, the third bolt that is on the back top of the flange required a bunch of extensions and angle drivers, and as I recall, I felt like I was only getting 6° or 7° of movement every time I tightened it. I kept the original bolts, but putting that starter flange back on was a very time-consuming and frustrating process.
GeneralDisorder
6,141
Portland, OR
Huh. I just removed the power steering reservoir and bracket and pulled the starter out the top. Bolts were no issue - double-wrench used on most of them:
I think the whole process was about 2 hours to swap the starter. Very easy. No issues with bolt access for me. I did the whole job with a 12 point box wrench and a second wrench for tightening leverage. The one inner/lower bolt I did from below.
My snout was loose also. I think this is probably more widespread that people know. Some of my bolts were in fact "backed off" maybe half a millimeter but the goo they used had solidified and they were kinda stuck like they probably weren't going to fall out. Starter had about 1/2" of play at the front with a prybar. None of the bolts were actually broken though so I was able to clean them and loctite them back in place.
