blutow
- 501
- 63
- Austin, TX
As I understand it, I should be able to temporariliy disengage the cooling fan for ~15 seconds by flooring the accelerator pedal.
I think my cooling system is working properly otherwise, with the fan kicking on periodically and then disengaging after running for a minute or so.
My assumption is that I have a problem with the time delay module or maybe the throttle position isn't being sensed properly. There is a switch assembly near the back of the motor that I assume is the throttle position sensor. My transmission is kicking down properly (I'm thinking they may share the same throttle switch/sensor, but not sure).
Any tips on troubleshooting? I am still struggling to navigate the TM's, so any help on where to look (or how to search better) is also appreciated.
