Manu7464
- 14
- 3
- France, Saint Jean de Luz
hello everyone, I have a Humvee from 1986, 6.2l engine, it drove very well but for some time it stalled on rough terrain
2 months ago, I almost ran out of fuel, I went to the bottom of the tank, arrived at the diesel pump, refueled and left impeccable!
I made some trips without problems (500 kms at least on the road), the rugged track (40 kms) without problem, with sometimes a small stall in my maneuvers to turn in too tight corners but he climbed hills without problem and theI made some trips without problems (500 kms at least on the road), the rugged track (40 kms) without problem, with sometimes a small stall in my maneuvers to turn in too tight corners but it climbed hills without problem and the engine sang!!!
2 weeks ago I did 15 kms on the road (the day before we had done a course on tracks a little sporty a little fast but nothing monstrous), and on the road when I returned I lost the box 2 times, it returned to neutral and the engine stalled! box to neutral and key stroke and restart and return without problem, next day tests on forest track and cold well but after 10 minutes it stalled as soon as I wanted to climb a hill!
I was waiting a few minutes and hop restart and a jump of 300m and engine stalled!
we checked the air line: everything is ok, no clogged pipe, everything is clean! niveua of box oil and color ok, engine oil level ok, coolant ok, it starts the first time, it turns correctly, we can send the horses to neutral, it holds cold, because after hot it stalls
today we checked the diesel filter, it was dirty, dirt in the bottom of the filter container, the prefilter clean, the filter was black with dirt, we cleaned everything and reassembled with the old filter (I'm waiting for the new one) and it still does the same thing
I will put the filter new as soon as I receive it but what does one have another idea? thank you for your help and time to read my novel![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
