Hello Guys,
I can´t seem to figure this out by myself. I had read a bunch in the forum here and in the TM´s but im lost now.
Problem:
Truck airs up fine and quick. Horn, Wiper and so on are working. Brakes are working, Handbrake is working. Truck running fine.
It airs up to about 125 psi, the air dryer purges for about 3 4 seconds but the compressor is not shutting off after that and the cycle repeats itself.
So the air dryer purges at idle every 30 40 seconds or so.
When the air dryer purges, the compressor seems to shut off for as long as the purge goes, then the little exhaust port on the governor purges and then the compressor seems to start again.
What I have done so far:
- I replaced the 3 checkvalves that are prone to corrosion on the two passenger side tanks and the tank on the drivers side with stainless steel checkvalves.
( today I noticed another checkvalve at the back of the wet tank... didn´t see that before... will replace this aswell with a stainless steel one )
- I replaced the governor from the compressor and checked its lines
- I dissassembled and cleaned the PPV ( had crud and dirt in it, rubber nose cone gasket thingy was still fine )
- checked the gladhands and drain valves for leaks
Overall truck status:
- I cant hear any air leaks on the brakes or on any stuff in the cab.
- I can hear something leaking in the stack when the truck is off. This leak goes away as soon as I press the break pedal a slight bit.
Can somebody help me fix this darn problem? Been reading and trying stuff for quite a while now.
Thank you very much in advance
Problem:
