Mep 802/3a lift pump issue
jmenende
378
Puerto Rico
Alright guys. I just took out the lift pump off a unit that even had the tappet stuck. That said, the issue is the pump fell apart when i took it out. The clamp, spring and piston just fell out. I cant get the piston to stay in and comes right out when i put in the spring and detente. I does not seem broken and I have not found a rebuild blowout to see if anything is missing. Any suggestions?
Josephml21
45
PA
LOL look at my thread right next to yours, I'm working on the same part and I can definitely tell you how to put it back together. My problem is I have two IP's that have different amounts of rings in them so I don't know how many actually go into a IP.
jmenende
378
Puerto Rico
Im having issues with the other side of the pump. The bottom where the big spring is at. It has a disc that acts as the detent and holds in the spring and piston in the middle. My piston will not stay inside and there is no pressure to keep the detent in place. Im trying to find out if there is a special way to turn the piston to get it to stay inside.
Josephml21
45
PA
Post a picture of your pieces and I'll number them for you
jamawieb
541
Ripley/TN
Inside the pump is a grove that holds the plunger in place. You have to actually take the plunger out through the top (outlet side). The plunger can't be removed from the bottom where the spring is unless the inside of the pump is damaged. You'll never fix it, i've tried on different units. What will happen is the pump will come apart inside the motor and say goodbye. I've lost 2 motors due to faulty pumps.
jmenende
378
Puerto Rico
Thanks for the heads up. Will get a new pump.
