itsmerandy
- 23
- 3
- Nixa, Mo.
Hello, I purchased a non running MEP-003a for $500 with just over 2 hrs on the meter a year or so ago and finally had some time to work on it. So I changed the fuel out on it and then rebuilt the Ambac IP and tried to start it, took a little bit to get it running but finally fired up on a couple of cylinders for a bit before the other two started working. It puffed out a lot of white smoke and finally cleared up, I ran it for probably 10 minutes and then shut it down. The next time I tried to fire it up it took a little bit to fire off but as soon as I let off the starter switch it died. So I did some diagnostics and found that the thermal shut off switch was open, so I bypassed the thermal switch and it started, ran fine until after it started warming up, then started missing and puffing black smoke out of cyl #3-4 exhaust and then dies. So my questions are - 1.) is the thermal shut off switch a one time blow or is it supposed to reset on its own? 2.) would it be the injectors causing the black smoke and stalling of the engine?
The engine did seem really hot after the first run, once I shut it off smoke was rolling out around the cylinder heads but I figured that was all the dead leaves and debre that got in it from sitting outside for so long, but worries me since the thermal switch opened. Any help would be appreciated. Thanks.
