Tne 3.55 on 22.5 with an 18 sd put you at about 1400 rpm and 70 mphOnly issue with the air ride swap and using axles from one is the gear ratios.. most are 3.55s to 3.90s.
The 915a4s use the same axles as the 915A0. A 4.44 so it would lose some of its low end grunt.
Top speed would increase about 17mph
