- 1,339
- 1,912
- Las Vegas Nevada
M1151A1What model truck is this?
Its an M1151a1What model truck is this?
if you didn’t remove the additional positive and negative cables required of 400amp and did not change out the Gen/PS bracket, than you had a 200amp. Buy a new correct length belt…M1151A1
wrong belt or your routed wrong….I got the belt completely off, pulled it into a straight line and it measures about 54.25" long. So just over double that length puts it around 110" or so in circumference I suppose.
I'm really thinking wrong belt. The routing diagram is right on the truck and it was definitely routed correctly.wrong belt or your routed wrong….
