My Diesel M37
G744
4,023
Hidden Valley, Az
I built this over two years, starting back in '73.
What I wound up with:
3-53N Detroit 3 cyl engine.
Spicer 3053 5-speed OD trans w/PTO.
Full air-over-hydraulic brake system w/gladhands for trailers.
Johnny-bar for trailer brake actuation.
11.00-18 Goat tires/wheels on homemade adapter plates. (those were steel-belted bias tires, BTW)
Warn lockout hubs.
Nasty-assed LOUD military air horns.
Arctic hardtop with 450 watt spotlight.
Stock pedals and steering.
5-ton dashboard.
55 Gal. aux Diesel tank.
15mpg average.
Top speed with the 18's @ 68mph. Earplugs recommended...
Sold like an idiot. Presently gathering the parts to build another one.
The last photo is my Nephew and a friend.
DennisDennisArmyTruckDriveway.jpgDennisArmyTruckDetroit.jpgDennisArmyTruckPanel.jpgDennisArmyTruckSteveGary.jpg
20,534
Warn lockout hubs.
5-ton dashboard.
15mpg average.
DennisView attachment 855231View attachment 855232View attachment 855233View attachment 855234
Dang that was neat!
I like it... That little Detroit is so cool and weight wise - I bet it wasn't awful. Air, oh my! Heck, I thought I was cool with a pair of air tanks and a schrader valve was neat. Real air and air brakes for a trailer would be incredible.
Let's gather the parts for two.
One for me and one for you!
G744
4,023
Hidden Valley, Az
The early days, I finally have something started.
Chassis & axles done!
I got really good at swapping out rear ends...this truck went on to absolutely ruin 13 sets of ring & pinion!
DG ps...like the flowerpot?
GT4U
22
IL
Did you have to do a front lift or anything to the M37? Considering a 353 swap but not sure if I'm up for it yet....
G744
4,023
Hidden Valley, Az
I beefed up the front springs a bit, as the engine and winch add a bit of poundage.
I took some leaves from M37 rear springs and interleaved the fronts to get a taller, beefier setup. The lasted many, many miles. I did have to make up longer U-bolts for them.
When I went to Goat tires/wheels, I had to trim the bottoms of the splash pans as they would rub on full lock turns.
DG
