Over the weekend I pulled the oil pan and replaced that gasket. Not a difficult task but by the end I was a little sick of laying on the ground
Hopefully thatās good for many years now.
Also tonight I pulled out the transmission. The 4 of the 6 bolts fastening it to the engine were oddly almost loose. And whoever last changed the fluid/filter definitely didnāt torque the pan bolts to spec cause those were also very loose. Makes sense why that fluid was leaking.
Upon inspection of my new 700r4 and 32 spline output adapter it turns out it came with an adapter for the extension housing/mount. I also previously purchased the āfactoryā extension housing on eBay for the 700r4 to the np208. Iām leaning towards using the āfactoryā one just so that itās cast iron. Shown in the 4th pic below.
