- 209
- 61
- 28
- Carmel IN
Hi All, My 1984 M1009 has a left rear tail light issue. At first the whole left tail light, brake light and turn signal light didn't work. I found the ground wire has rusted off. I fixed that and now have a brake light and turn signal. But the left tail light still didn't work. I thought ok even the bulb looked OK must be a bulb issue. My right tail light worked OK so I swapped them. Same problem, left tail light not working and right tail light working. I figure there must be another ground wire not working but not sure where to find it.
All other lights all the way around the truck work just fine.
Oh and the inside of the left tail light socket seems to be ok. At least I don't see any rust or corrosion anywhere in it.
Wanted to see if anyone had some thoughts.
Thanks
Thanks
