MMSINDUSTRIES
- 6
- 3
- Littleton ma
I have recently bought a Cucv m1009 that was slightly disassembled. I’m having no good luck finding solid for sure answers for my questions. I would like to start this thread to help others like me.
So to start off.
1. Battery terminal connection I cannot find a clear picture of how the battery’s should be correctly hooked up. See attached image.
2. I would like to know a list of the tail light/turn signal lights, aswell as all of the small marker bulbs
3. My Cucv is missing the gen light harness they were completely cutout and I cannot find any cut wires except for one black wire. I was having an issue with the engine not spinning over when I turn the key so I grounded that wire after checking numerous other things. That did the trick, the truck starts with the key and charges now but I want to make sure this is right. If someone either has a diagram of the gen light harness or a clear picture of the wiring so I can know where to start.
I would like to keep this as a on going thread that other people can update aswell as I can. I’ll add some other pictures of my rig. I’ve done quite a bit of work in the dews weeks I have had it. Thank you
So to start off.
