.Hello forum.
Do you suggest to block the air ride system when doing heavy offroad, like on steep hills / dunes? What else you would do when crossing a sandy desert zone, except air pressure and 4wd mode engaged?
Christian
.Seem to recall TM's say pinned in when off road..... while discussions in the FMTV forum on this topic tends to say unpinned off road for comfort. IMHO that would be true except maybe in the realm you hit on.... where a flick of cab to one side ....... say as you crest a dune at a slight angle instead of nose straight down... that cab shift might be the slight extra inertia needed to make you roll. So maybe call it.... the dicier things are getting... pin it. As in if you feel so nervous you get out and really inspect the angles and twist-ies before proceeding..... then pin them. Heck your out anyway so no big deal. When it is just ruff terrain, but not "dicey" then unpinned likely fine. YMMV
that of course is IMHO.
I agree, the inertia of the cab moving an inch is not going to make the difference. If you flop, that was going to happen anyway. I would think having the compliance and shock absorption would be better for your truck when off-road compared to a pin in a “thin” piece of metal. Your best scenario is good working bushings, airbags, and shocks.The cab shouldnt move side to side... if it can, it will still do so when pinned...
If the cab could move enough vertically(limited to about 1.9" total travel) to push you over the edge, you have already imparted all the energy necessary to rollover anyway...
The only ref I recall is to deflate it and pin it for shipment...
I see no issue running it driving under any condition... From normal ride height it only moves ~ +/- 0.95".
Maybe am being to safety conscious...... don't mind risky-ish offroad travel..... been there / done that / will again just like to cover my bases..... especially in the FMTV's Tin foil cab.
