M1083A1 Electrical Maladies Starting at the Disconnect Switches
Lugnuts
265
Myakka City, FL
honestly I've not understood why more offroad type folk have not gone to something like this. Dont know if they make these larger but guess one could put a few on a manifold to accommodate something larger than a jeep hub.
Or even a tank that works like a radiator overflow bottle but with air. Or a closed overflow bottle *system where you put a little vacuum on it at install giving room for things to pressurize into it when needed then drop back to slight vacuum state when not hot and working.
*not sure I like the closed system. if a leak is in it when in water the vacuum might suck water in. Granted once it sucks in enough air to equalize instead of being at vacuum..... then the system is negated but at least it is not "sucking "water in
Interesting!!!
coachgeo
3,546
North of Cincy OH
Yes, it works, at least I've never had river water in my drinking tanks.
I looked and was not able to find the ones I have, maybe they don't make them anymore.
well this looks interesting. make a manafold out of PVC. Place front edge of bed near spare? Run all your vents to it. Put a couple of these on it ..... say on each capped end?
20,760
Neat idea - and that will keep out the mud building critters with wings too!
