HMMWV Humvee M1123 Build Thread
Vapor Trail
282
Kentucky
SO I got my M1123 in. I'm mechanically inclined but I haven't done much automotive work. My plan is to do something like the Predator ATVR-6 (internal cage, not exo). I'm going to Line-X inside and paint the outside satin sheen, build a cage, new bumpers, new gauges, all new wiring, brakes, halfshafts, tires, and wheels. For the powerplant I think I'll get an aluminum 6.2 liter L86 and a 8L90 transmission. Probably put lockers on it too.
Vapor Trail
282
Kentucky
I’m not a fan of body lifts but I see why they’re used in these vehicles so often. I’m building one now but not just cheap spacers. I’m making the four corners from scratch 1.5” taller. Not just for bigger tires but when Govplanet picked it up it squashed the body where the forks were a little bit because the body sits lower than the frame. I have a big forklift and if I want to pick it up I don’t want to worry about board spacers. More pics as I move along3A4E7DE1-AD19-47AC-AA66-FA727B04002B.jpegDA968BBD-8C4F-4FD7-B14D-E490287E241B.jpeg
Vapor Trail
282
Kentucky
So I got the seat bases started. I’ll add extra bracing underneath and a sloped piece where all four match that goes over to the door sill. Later on I’ll cut speaker holes in them maybe. The rear seats have an opening on the front. I’ll put a removable door there for storage underneath
Vapor Trail
282
Kentucky
So for the lift I put spacers in the middle but on the ends I built new body mounts which are much lighter but just as strong and they incorporate the holes for mounting the bumpers. I took off the existing ones and measured them and made my changes but I didn’t build them square in the shop. I built them in place on the machine so that the important surfaces would be straight and even. This made for ugly and misfitting joints because the frame rails are so cambered and castered out but now the hood mounting surfaces are perfect and the cracking fiberglass is no longer in a bind.
30836992-BE51-47BC-B725-D7536E5D4563.jpeg58F59F01-E186-4307-B3BF-A52429432237.jpegB1C89618-C197-494D-A6B2-969DF8F55B13.jpeg
Vapor Trail
282
Kentucky
Also, I realized the way it originally sat the rear top fender surface wasn’t parallel with the other straight surface which is the door sill area. I used the rear mounts to straighten that up so that gap between the two looks correct now
  • Like
Reactions: OBX
Vapor Trail
282
Kentucky
I found some pictures on the net of some bumpers that looked pretty good so yesterday I changed some things to fit my needs and built this one. I found another one I like better but I already had this done so I might do something different later in.
0C7F5350-9D54-4837-A6F7-BE9BCA6B016F.jpegD80835C7-C82A-4CD4-B47E-EFB7FA5C14FA.jpeg45ED6FD5-4CDB-4D87-8B6F-F3A89ECEB52A.jpegE24C1753-4FDB-4CD6-95A6-14FDFCFA8E12.jpeg
Vapor Trail
282
Kentucky
Looks great! Did you tie the rear section into the frame somehow?
I thought about tying it in to the bumper but it’s mostly just for aesthetics. I don’t want to get rear ended or back into a rock and it tear up the cage too. All the cage points are around the edge and the frame is way inboard so it’s just not worth the effort if you aren’t into heavy off-road stuff
Vapor Trail
282
Kentucky
Also called tube doors. I thought about some perforated inset metal or something but the idea is to keep the feeling your still open to the elements but not be able to fall out. I think they're called rock doors because the rock crawlers can see what's going on through them better. I think it will look better when they're all painted to match the body. If I change my mind i can make a set of something else that pops onto the hinges later.
