fmtv winter front cover .
snowtrac nome
140
western alaska
I received my winterfront cover, I cant figure out how to install it, and cant find any references in the tm about it. Any one got any pics of one installed, -30 is coming in a couple days and I don't want to be fiddeling around than trying to get it on.
hs10
Minnesota
I have the OEM version and have installed several times. It is a challenge. I am exploring if an external version would accomplish the same thing and be easier to install.
coachgeo
3,484
North of Cincy OH
pretty sure their is video on youtube. Used it to put mine on
Update- of course now I can't find it. Not finding a write up in her either. hmmm?
Ronmar
8,186
Port angeles wa
I don’t know how effective an external one would be unless you can block that big gap between radiator and intercooler at the bottom.
I was thinking about one in 3 or 4 parts with some perimeter components permanently installed. of course this would be easier if they didn’t put the gladhands right there and run a bunch of other wiring and hoses around the perimeter:)
TomTime
1,672
MD.
I don’t know how effective an external one would be unless you can block that big gap between turbo and intercooler at the bottom.
I have a radiator cover for my M1083A1 but haven’t put it on yet. I have looked at the access area and it doesn’t look like it would be to hard considering other things that are hard to do on these trucks.
It appears to me that it covers from the bottom of the intercooler to the bottom of the radiator.
For my MTV I found the “Cold Weather Radiator Cover Installation/Removal” in TM is 2320-366-20-5 under chapter 18, 18-12, page 18-66.
The first picture shows no cover installed and the second picture shows cover installed.
hs10
Minnesota
I have one of these. Anyone got pics of it installed?!
- Here are some photos of the cover installed. It is very challenging to get the cover past some of the hoses. Very difficult to get it positioned to use the top bolts, so I use paracord to secure the top section.
GeneralDisorder
6,050
Portland, OR
Nice. I'll have to attempt installation. Mine has never been installed but it could be handy if I head up to the mountain. The warning about not using it causing damage to equipment is interesting. :oops:
Ronmar
8,186
Port angeles wa
The thermostat doesn’t know what temperature it is outside And it being at the end of the hot side, it will repeatedly close the barn door after the horse has escaped. Repeated heat and cooling cycles from 180F to possibly below freezing is not conducive to long engine life. Diesels do best with a hot stable operating temp and this is difficult if the cooling system keeps feeding it large gulps of ice cold coolant… this can crack heads, blocks, warp oil coolers and cause seals/gaskets to fail prematurely.
coachgeo
3,484
North of Cincy OH
In the PDF the Geo poste
dView attachment 883483
oh...... that warning... lol
seriously though, how warning was mentioned earlier left me thinking there was some warning about the covers known to causing damage from failure orrr...??? that somehow i had missed hearing/reading.
In my case.... by the 40f thing...... cover will be on a bunch
the writing of the WARNING in the TM though to me appears to tie to the "must remain on between -26 and -50" portion of the box... and not the whole "from 40f and below"
thought about permanently attaching it or something similar where the main cloth cover Velcros ..... like say the bottom half can be unVelcro-ed and flapped down and rolled up / tied back out of the way. or better yet flapped to the side(s) like opening curtains and tied off.
ramdough
1,731
Austin, Texas
That is a creative solution. Thanks for the pictures!
Has your fan ever cycled with that on?
Third From Texas
6,663
Corpus Christi Texas
Yeah, easier for me to just not drive the truck on the two days a year we get below 40 degrees here.
;p
Guruman
Not so new member
1,074
Cody, Wyoming
The way I read this, you can install the cover in temps under 40F, but it's REQUIRED under -27F.
So over 40F no cover.
Between 40F and -27F cover optional
Under -27F cover mandatory.
Right?
hs10
Minnesota
Great information, THANKS! The OEM cover appears to only cover about half of the radiator and just a small section of the air cooler.
I see temperature down to -35 - -40 periodically. At these temperatures should I also use a cover over the grill?
