Levi75
- 13
- 3
- Spraggs pa
Is there a complete schematic of the air flow circuit? (starting from the compressor to the tank and to where from there?) If so, what manual is it located in? My truck only has one air tank (I purchased it this way), it is missing the other one. Mine is hooked up this way: Air line is coming from the compressor into the front of the only air tank, and then exiting the rear of the same tank with a red plastic air line. Then the air line loops back around the air tank, and then it connects to a steel line that goes into the air pack. There is another air line that is metal and sets inside the frame, that is not hooked up, and I traced it back to the govner.
I removed the moisture valve on the air tank, and threaded an air gauge in it to read the pressure, and after starting the truck, it pegged the air gauge beyond the highest reading number - beyond 200 psi.
