gslader
- 287
- 63
- California
more info to help you search withI'm looking for an interior / exterior temp gauge that would fit in one of the cut-outs for the rocker switches in the dashboard (44mm x 22mm). Anyone have any luck tracking something like that down. I bought one of these but it doesn't quite fit (too small). Any suggestions great appreciated.
3d print an adapter to snap into. What size hole is this made for?I'm looking for an interior / exterior temp gauge that would fit in one of the cut-outs for the rocker switches in the dashboard (44mm x 22mm). Anyone have any luck tracking something like that down. I bought one of these but it doesn't quite fit (too small). Any suggestions great appreciated.
@Guruman: I've poked around a bit looking for adapters - the temp gauge that I bought is for a Toyota or Hilux (and unfortunately the only dual gauge temps I can find seem to be made for Toyota) and they seem to have a weird proprietary size (either 40.5mm x 22mm or 33mm x 22.5m) and I can't find an adapter for them. There are plenty of adapters for type L rockers to type V rockers but none that really fit the gauge I have.I'm looking for an interior / exterior temp gauge that would fit in one of the cut-outs for the rocker switches in the dashboard (44mm x 22mm). Anyone have any luck tracking something like that down. I bought one of these but it doesn't quite fit (too small). Any suggestions great appreciated.
cut size. Though you might try Rome Truck in GA. Lot of folk get their LMTV OEM-ish switches from there.....
@coachgeo: Was there a link in your post or were you sharing the cut-out size (sorry if I missed something).
Who makes this?I'm looking for an interior / exterior temp gauge that would fit in one of the cut-outs for the rocker switches in the dashboard (44mm x 22mm). Anyone have any luck tracking something like that down. I bought one of these but it doesn't quite fit (too small). Any suggestions great appreciated.
I bought one of these: https://www.amazon.com/dp/B0B1WH2X34Who makes this?
I really appreciate the footwork and wish the solution was that easy. The only temp gauges I have been able to find are for Toyota/HiLux which appear to have an odd proprietary rocker cut-out size (40.5mm x 22mm) so very close to the L-Series cut-out but different enough that it doesn’t fit. I thought about tryin to to modify and V-series adapter but I don’t think that will work either.The rocker cutouts in the LMTV dash are "Series-L"
1.734” x . 867” [44.0mm x 22.0mm]
The more common automotive rocker is a "Series-V"
.83" x 1.45" [21.08mm x 36.83mm]
So you want an adaptor for a Series-V switch to fit into a Series-L cutout. It seems that like those crazy military engineers, the crazy Canadians use the L-series in their Polaris vehicles (which means there is a demand). Given that the thermometer you posted displays in "C" (which appears to be Canadian for "cold" or something) it should work.
With that little tidbit of knowledge, I was able to find the adaptors in several places:
Allows the use of V-Series rocker switches in L-Series cutouts.
Allows the use of V-Series rocker switches in L-Series cutouts.www.otrattw.net
OTRATTW POLARIS L-Series to V-Series ROCKER SWITCH ADAPTER | eBay
Switch Hardware V-Series rocker switch adapter to fit into L-Series rocker switch cutout. Allows the use of V-Series rocker switches in L-Series cutouts.www.ebay.com
This is the one that I bought: https://www.amazon.com/dp/B0B1WGSTNG?ref=ppx_yo2ov_dt_b_product_details&th=1Who makes this?
I think "Type B" in the link is the size you're looking for. Look like there is a difference in size from "Type A" and "Type B".This is the one that I bought: https://www.amazon.com/dp/B0B1WGSTNG?ref=ppx_yo2ov_dt_b_product_details&th=1
They do have a different bezel design and clip. I think both are 22x33, though.I think "Type B" in the link is the size you're looking for. Look like there is a difference in size from "Type A" and "Type B".
When I select Type B the size changes.They do have a different bezel design and clip. I think both are 22x33, though.
A & B is just the distinction between normal and the communist format.
