DIVE DIVE
- 778
- 93
- Chesapeake, VA
After priming the fuel system up to the IP: four ten second cranking cycles with all injector fittings loose. My particular order of priming was injector 3 then 5 and 7, then 2, then 1,6,8, and 4; closed them off as they had visible fuel. Once all had visible fuel at fittings, installed glow plugs and wires. Cranked for ten seconds. Noticeable sputter. Cranked for ten additional seconds, shuddering and firing haphazardly. Cranked an additional 10 seconds and she fired up came up to speed, shuddered, hunted, and shut down. Half throttle started, fired right up (after glow plug wait) and spun up quickly, let off the throttle and she came down to idle. It was apparent at that point that all cylinders were receiving a good fuel supply by the low and steady idle. Let run for 10 seconds and shut down with the key.
