And the lowers on the M1082 trailers have a different diameter (Awesomeness makes those as well, I believe)The uppers are different between the 2.5t and the 5t.
rear or front? granted Im not sure their is a front one lol. Spent more time dealing with my rear one.Is there a current known good source for sway bar bushings, especially the uppers? My lowers seem good, but uppers have totally left the building.
I always assumed that the front pivot point of the sway bar had a bushing as well, but good point.. I've never looked.rear or front? granted Im not sure their is a front one lol. Spent more time dealing with my rear one.
FMTV M1078 Rear Sway Bar Bushing Kit Complete 12417624 12419026 12419029 ⋆ DP Equipment LLC
FMTV M1078 Rear Sway Bar Bushing Kit this has all the parts you need to replace the rear upper sway bar bushing on the 2 1/2 Ton LMTV trucks. Complete kit does one side. Two kits do the complete truck. Check your truck the original rubber bushings breakdown and the rubber is gone resulting in...dpequip.net
Yeah, when you consider that you need four sets to do a truck (plus the lowers).Hoo-doggy. Those folks sure proud of their parts…
I usually bite my tongue when I see these posts. If you think it should be done cheaper, I'd like to see you try. I practically give mine away, and they still aren't as cheap as I'd like. And the cost of the materials just keeps going up.Hoo-doggy. Those folks sure proud of their parts…
Agreed. I'm all in favor making your own when they can't be found (or for a reasonable price). As I said, the metal washers and sleeves likely are not needed if your truck has them intact (either way, that's only a couple dollars). We're talking about the squishy bits. What hits the wallet hard here is you need four sets per truck (and that $400 from the above mentioned vendor).I usually bite my tongue when I see these posts. If you think it should be done cheaper, I'd like to see you try. I practically give mine away, and they still aren't as cheap as I'd like. And the cost of the materials just keeps going up.
Didn’t mean to ruffle any feathers, and my comment was about their parts in general, not the bushings specifically. A lot of that stuff they’ve got posted is being done cheaper, or at least sold cheaper, and fairly readily available. There are things being sold by places I won’t further mention, at about 400% mark up, that can be readily bought off the shelf. I don’t mind paying some extra for somebody else to do the leg work, but I don’t expect to put somebodies kid through college over a single item. Exaggerated, but that’s the gist.I usually bite my tongue when I see these posts. If you think it should be done cheaper, I'd like to see you try. I practically give mine away, and they still aren't as cheap as I'd like. And the cost of the materials just keeps going up.
I’m not sure what’s left of mine. They just got a cursory glance while I was doing other stuff, because I’d just watched someone’s video about changing them out. Same with the cab bushings, but kind of odd in that case. The uppers look practically new. The lowers have left the building. Completely Mia.Yeah, when you consider that you need four sets to do a truck (plus the lowers).
Im not really sure you need the washers and sleeves.
And with that out of the equation, I bet that there are civilian solutions if you know the specs (L, ID, OD).
Some place like this is a bit more realistically priced:
Prothane 19605 Pivot Bushings - OD 1.5 in, ID .752 in, Tube Length 2 in | Suspension.com
Universal Bushings made by Prothane | 19605 Pivot Bushings - OD 1.5 in, ID .752 in, Tube Length 2 in.www.suspension.com
there is a rather long thread in here on trying to find available generic or name brand in right size bushing for the lower. Far as I recall there was no success. Maybe some of the resources brought up in that thread might help though.....
But IMO, the trick to beat the high cost in a case like this is to find a civilian solution (not a surplus). I see similar sized mass produced bushings selling for ~$15-20 for the pair.
try thisthere is a rather long thread in here on trying to find available generic or name brand in right size bushing for the lower. Far as I recall there was no success. Maybe some of the resources brought up in that thread might help though.
Hence why on boards like this it is highly recommended for everyone to SEARCH FIRST before posting. You might find parts of your questions are already answered.
Greaseable polyurethane sway bar bushings
Just weeks after getting my M1078, the sway bar bushings fell apart, and were soon completely gone. I decided to make some heavy duty polyurethane replacements, and make them [optionally] greaseable. Here's the CAD model so far... I 3D printed a prototype, to test fit, and everything looks...www.steelsoldiers.com
It's just that every few months, another new member comes in and starts this same discussion, about any number of parts that are "too expensive". For all the talk, there are few/no cheap solutions of equal quality found.Didn’t mean to ruffle any feathers, and my comment was about their parts in general, not the bushings specifically. A lot of that stuff they’ve got posted is being done cheaper, or at least sold cheaper, and fairly readily available. There are things being sold by places I won’t further mention, at about 400% mark up, that can be readily bought off the shelf. I don’t mind paying some extra for somebody else to do the leg work, but I don’t expect to put somebodies kid through college over a single item. Exaggerated, but that’s the gist.
Apologies. I won’t comment further about cost, good or bad. Happy Holidays.
I've ALWAYS stood up and stated support for anyone making products like that.It's just that every few months, another new member comes in and starts this same discussion, about any number of parts that are "too expensive". For all the talk, there are few/no cheap solutions of equal quality found.
For the bushings specifically, there are so many costs that go into doing these well, from the cost and time of making the master patterns and molds, to the ~$85/gal material itself, to the consumables (e.g. paint sticks, rubber gloves, mold release, black dye, shipping boxes, grease fittings, etc.). Not to mention $1000 worth of equipment. For people to walk in and casually scoff at the price just means they haven't even started thinking about what it takes to make them. Low Volume Production of anything is tedious, and there are a lot of costs that add up.
