HelluvaEngineer
- 80
- 28
- Atlanta, GA
I posted about a year and a half ago about the botched TH400 rebuild job I got at a local shop. It lasted about 900 miles until recently when it started revving high, slipping, and the fluid was burned. It's now at what seems to be a much better local shop, and the shop owner has been keeping in touch with me on progress and asking questions about parts specific to the M1009.
The transmission is rebuilt and back in the car, but they are trying to debug the vacuum system because it's skipping shifts and is generally all over the place. Thankfully, they seem to want to get it right. They said someone bypassed the vac regulator altogether and they figured that out, but they say the pump is jumping between 20 and 5 inches at idle. So they asked me to order some replacement parts.
Unfortunately, I found out that both parts are now basically unavailable. I told them I can get the vacuum puck on the pump, but the shop owner is concerned the teeth on the pump may be worn and it's bouncing around on the cam.
Does anyone have any recommendations for locating parts or alternate solutions? At this point we're also considering installing a Lokar manual shifter, but I'd prefer to keep it original Any thoughts? Thanks in advance.
Edit: if we go manual they are recommending a new manual valve body, I believe. The note about the Lokar shifter above is irrelevant.
