I'm sure everyone here is familiar with the vacuum control valve that controls the vacuum to the transmission vaccum control module to adjust your shift points.
From TM -34 Pg. 249
Can this item be bypassed and a direct connection be made from the vacuum pump to the modulator if the modulator is an adjustable one?
If not, why not?
I'm going to assume that having BOTH, the VRV hooked up and an adjustable VCM is probably going to make the entire -34 VRV adjustment procedure null.
If that is the case can someone point me to a "verified" OG approved VCM that is non adjustable?
Thanks.
-Squib
From TM -34 Pg. 249
If not, why not?
Thanks.
-Squib
