- 181
- 106
- 43
- Wisconsin and Illinois
Trying to pull out the steering gear/box.
The TM doesn't specify sequence or tricks.
I tried starting with intermediate shaft that goes to steering box........loosened the bolt/nut but can't get the shaft to release from the spline shaft of box. In other trucks the steering column will 'collapse' on itself with some modest force.
Is that the case on the HMMWV? Does the intermediate shaft telescope/collapse on itself in getting this off?
Or do I need to unbolt the box and get it to pull down?
Also is it possible to get box out with pitman arm still on, ie remove pitman arm from steering link and then pull out box in one piece with pitman still attached? What if I also detach the idler arm? Can the steering link still stay attached at TRE's at end and just replace all this?
Really having hard time finding good pics/tricks/video on this exact part of procedures.
