- 849
- 1,740
- 93
- N. Central Idaho
Happy to report I finished all repairs (so far!) and have been running in the driveway getting temps up and leak checking. Only issue at present is the turbo oil return is seeping. Had trouble getting the bottom end on as I forgot to install until 1st run and it was a bear getting it on. 1st crank took a shot of ether then every morning cranks for less than 1sec before starting. Hadf some noise at first the large nut on #3 injector was loose and it was squirting some fuel. Tightened and purrs like a kitten.
With 2 new pistons, sleeves and rod bearings I want to break them in slowly. I can't find the run in spec in the TMS or on here using search. So I run at low idle for a minute or two while checking for leaks then bump to 800 RPMs for 5-10 minutes, then 1,000/5-10 mins, 1,200/5-10 mins and finally 1,500 RPMs until temp gets to 120/140. Takes a few but I leave the block heaters on all night so it will be warmer starting up.
Was going to get fresh fuel today but it's snowing so I'll wait for another warm spell.
Can anyone point me to where the run specs are located in the TM?
Time to party!!
Time to party!!
