I could use some help from someone that has rebuilt a 6.2. I'm trying to rebuild the engine from my M1008 and the main bearing diameter are all different sizes. I put the main caps on without the bearings installed and the hole the bearing goes in ranges from 3.1389 (#5) to 3.1424 (#1). The GM rebuild manual and the TM are no help since they talk about "Select fit" main bearings that nobody has ever heard of. When I look for bearings I can only find standard and oversize, not random sizes. I can't believe the crank bore at the block are all different sizes from the factory. How have you guys solved this in the past? It's nearly impossible to find someone that will line bore the crank bore near me and I can't find "select fit" main bearings.
