Vic_949
- 12
- 8
- Bakersfield ca
So I took off my starter solenoid to test it inside it had a spring and a metal thing to push the starter gear out when I was done. I screw back the starter solenoid I put the spring back and the metal thing I put the solenoid back on the starter I connected the wires correctly when I connected all the battery wires and I only had 1 cable to put on the battery it sparked a lot when I put the starter in for the first time and I wired it correctly it didn’t spark a lot when I put that last battery terminal help.
