jmenende
- 423
- 63
- Puerto Rico
Hey guys I have an issue maybe some of you can help me with. My 803a did not want to start and I tracked the problem down to a stuck fuel pump.
So i took out all 4 one by one to avoid mixing them and put them back once i made sure the lever and piston moved freely. The issue is I do not get adecuate pressure off each pump outlet. The more i tighten the top nut the less fuel comes out till it stops (its possible i assembled it in the worng order but i cant find the blowout to confirm. Im pointing at the top nut that contains a barrel, spring, plunger, large washer and two small washers. thia part unscrews from the pump body). The shims and pumps were left in the exact order. My pump model is 751-41174a lister petter. Any hints?
